W40 OIL FILTERS
Anonymous-0
Am looking for info on where one might find an oil filter for a stock w40, or anything that will interchange, thanks.
Welll...Wix 2000 and 2006 catalogs show IH WA40, WD40 and WK40, but no W40.
WA40 and WK40 list Wix 51125
WD40 lists Wix 51155
51125 is a Cartridge Lube Metal Canister, 7.579H, 3.264 OD, 0.480 top ID, 0.875 bottom ID. Catalog says used in IH tractors only.
51155 is same type, 7.375H, 4.188 OD, 0.594 top ID, 1.281 bottom ID. Used in Galion, IH tractors, Schramm and Worthington comp'r's per catalog..
Sorry, no engine ID stated; do see other catalog listings for 51125 in SOME (not all) C152, C248,C264 engines. (ditto for 51155 in var D-engines).
Don't know if that's helpful or not.
Appears to be the same filter that was used on the early Hs and also the Ms, 400s, and 450s as well as the F20/F30. I've got those in stock.
