alternator charging
Anonymous-0
Im installing a Cat 3208 in a machine and have no space to install the alternator on the front side of the engine, can you install it in front of the engine with the pulley facing the motor? The alternator will be turning opposite direction, will it still charge?
It won't matter. That is how MM did it on some of their tractors. Alternators can spin both ways.
What make of alternator?
It makes no difference to the actual charging mechanism, but the pulley MAY fall off!
Bosch and Motorola/Prestolite, for example, typically have their pulleys keyed in place.
Most Delcos ans many othere have no key in the pulley (or a provision for one), just depend upon the pulley turning in the direction that tightens the nut.
If you run that type of alternator the opposite rotation the load on the pulley will always be trying to work the nut loose. I would GUESS a little LocTite to secure the pulley and nut in place would solve the POTENTIAL problem.
You might look for a reversed rotation fan, because the reversed fan on the alternator may not pull air through it as well.
Gerald J.
Unless he's got a BIG electrica load, the alternator will be fine with the stock fan.
On one of my Oliver / Chevy V8 conversions, there was no room to mount the 10 SI alternator in the normal position. I mounted it facing the engine, turning backwards. CCW. Never a problem with it even running a CW rotation fan in CCW direction. Have put over 6000 hours on that tractor that way. Not a toy, this was one of my main farming tractors.
I never worried much about poor alt cooling fan operation because the electrical load is pretty light (just lights and ignition, no AC, alt runs cool enough to keep a hand on it.)
No alternator problems and the pulley has never screwed itself loose.
(quoted from post at 09:38:19 06/25/09) It makes no difference to the actual charging mechanism, but the pulley MAY fall off!
Most Delcos ans many othere have no key in the pulley ), just depend upon the pulley turning in the direction that tightens the nut.
If you run that type of alternator the opposite rotation the load on the pulley will always be trying to work the nut loose. .
Absolute nonsense Every Delco I've ever seen on a car/ lite truck, and I've torn down a lot of them, had a right hand thread nut with no key, and last time I looked, cars and truck engines turned CLOCKWISE.
What may or may not make a difference is fan direction. Things like Corvairs had a reverse pitch alternator fan, as the generators and alternators on those ran CCW. However, if your tractor doesn't have much in the way of load, you'll probably get by fine.
We once converted an old Allis M crawler, reverse drove the alternator off the mag drive. Worked just fine.
"Absolute nonsense Every Delco I've ever seen on a car/ lite truck, and I've torn down a lot of them, had a right hand thread nut with no key, and last time I looked, cars and truck engines turned CLOCKWISE."
WHAT is "absolute nonsense" about what I posted?
YES, alternators are commonly driven clockwise, and if you stop to figure it out, the RH thread nut is in contact with the clockwise-rotating pulley, having a tendency to keep it tight, rather that to loosen it.
What's nonsense about that???
(quoted from post at 23:00:46 06/25/09) "Absolute nonsense Every Delco I've ever seen on a car/ lite truck, and I've torn down a lot of them, had a right hand thread nut with no key, and last time I looked, cars and truck engines turned CLOCKWISE."
What you describe only happens in Obamma land. What I described is the real world, the world in which you could leave the nut completely off and the pulley would still slip. In fact, you could have one of the rare reverse rotation marine engines and your tractor would STILL be in reverse. The only way to change this odd happenstance is to change the rear wheels side-to-side so that the traction tires face the opposite direction.
Ok, you got me. I was thinking of the comparison to Corvairs. They DO rotate the oppostite direction, but they STILL USED a right hand thread nut and no key. The fact is that if they are properly tightened, they will not slip. Part of this proof is in the activity I used to engage in--drag racing. The incredibly fast change in engine RPM's up and down has not resulted in a rash of loose Delco nuts over the last 40 some or whatever years.
I've seen a couple come loose over the years, even in normal rotation. One was a Delco installed on a Deere 4630 by an official dealer mechanic. He apparently did not get it tight enough and it rattled off and got flung the belts/fan. Sounded like the operator needed a change of shorts after that was over!
