ford 3000 tarctor starting problem
My ford 3000 gas tractor wont start. a new starter has been installed- no help. It (start relay?) clicls continuosly when the key is turned to the start position, but the engine does not turn over.
Any ideas?
lloyd
[email protected]
Check the battery cable connections. Remove the cables at the battery. Clean the cables and the posts, and reinstall making sure the connections are tight. Check the connection where the ground cable connects to the frame or engine
Have u checked the netural saftey switch if its not that then i would check batt an cables
that starter need alot of juice.. a dead battery and a jumper might not do it. Put your volt meter on the bat and try to start.. if volts drop way down.
if not.. is the engine hydrolocked?
post back
soundguy
