bad leak/hydraulic?
Anonymous-0
the right side of the lift under the rear axle of my 1940 9n leaks steadily.any quick fixes or do i have to remove the axle and tighten or replace something?
If it's leaking at the big pin holding the 3pt lift arm.. then yeah.. pull left axle trumpet, remove chunk, and you can repalce / work on both pins.
soundguy
