Here's a sharkbite coupling installed on Pex tubing. It will also fit copper pipe, but you need to clean the copper pipe with steel wool until shiny. You also need to use a tube cutter
when making cuts. Then you just push the sharkbite coupling on the copper pipe until it's seated. I put 100 psi of air pressure on one these and held it under water and it never leaked. They are pricey. Hal
