orry, rebel (but I do like your handle), ethanol has an affinity for water & in simple terms, sucks it up like a sponge. That is why is is the primary component of such gas-clean-up products. If gas alone has water added to it, they separate and when the water hits the engine it won't run, BUT adding alcohols to the gas water mix causes the water to be suspended in the alcohol and and little by little it passes thru the engine, maybe not running its best, but at least running vs stalled. It didn't 'chase it away', it sucked it up.(quoted from post at 16:02:10 01/05/10) Ethanol chases away water.
It is the major component in Stabil fuel conditioner
appreciate your subtle points, but you can not gain anything above the 75,000 BTU/gallon no matter what the compression &/or advance. Compare to 115,000BTU/gallon of gasoline. It really IS that SIMPLE.(quoted from post at 19:04:31 01/05/10) The reason you don't see or miss the loss is that it is diluted by running only 10% ethanol in 90% gasoline. Which puts you in the position of measuring a 4% loss......requires care.
Agreed, but if the octane rating is bumped up two or three points (as most 10% blends are) the electronic ignition should advance - but its only gain if you have a "higher" compression engine.
es, ethanol & virtually all of the dozens of alcohols like water. I wouldn't dump the bottle od drug store isopropyl into you gas tank to help with the water problem, since the label states that it already has 30% water content.(quoted from post at 21:10:51 01/05/10) The biggest ethanol plant in WI is in bankruptcy and waiting to be sold to an oil refiner. Many have had money issues. Bio-mass is where it is at, not corn.
As far as water in gas,isopropyl alcohol is used more for gas line anti-freeze. Methanol is also used, but not ethanol. I have heard of the problem with ethanol blends if you let it sit for awhile, but as far as attracting water, I don't know.
hich came first? The chicken or the egg?(quoted from post at 22:49:25 01/05/10) "But the U.S. ethanol building boom is over. 'It all came to a screeching halt when our friends on Wall Street manipulated the commodity market,' Fagen said"
I think this comment is very valid. We should take notice of what has happened as Wall Street may very well destroy what is left of the American farmer too.
A few years back, I was listening to a discussion on NPR where two "experts" were arguing over if ethanol was really reducing the country's dependence on oil. I thought "ya know, if the net gain from corn based ethanol is so small that we all can't agree that it's reducing the country's oil consumption, I have my doubts that ethanol is really worth all this effort."
I know there is a camp that wants to reduce our dependence on foreign oil. Part of me says, heck, let's drain the middle east. Once it's gone, then they will have absolutely nothing left over there but sand.
At the end of the day, I favor eliminating all the subsidies and tariffs and let corn based ethanol stand on it's own. If it can compete with sugar based ethanol, great. If it can't, than that's the free market at work. Just my $.02
You can't cherry-pick and use the potential gains available in engine refinement for E85 and apply those to E10! Yes, 5 to 7% gain is possible for E85, thus partially offsetting the 30% that it is down on energy, thus resulting in the widely reported/measured ~23% miles per gallon loss.(quoted from post at 15:21:08 01/07/10) As I stated in both of my posts, My Prius makes more MPG with 89 octane E10 than it does with 87 octane gasoline. E10 is 10% ethanol, 90% gasoline which is only down 3.5% on BTU's compared to pure Gasoline,
Your own admission that an engine optimized for ethanol can gain 5-7% efficiency, while only losing 3.5% BTU's with an E10 blend.
Nowhere in my post did I claim to gain mpg while burning E100 VS gasoline.
(quoted from post at 15:58:43 01/07/10) You also say that the same modifications that allow more efficiency with ethanol would apply to any other fuel as well. Not in the case of gasoline. Best burn efficiency is if you run cylinder pressure right to the point of detonation. You can run more cylinder pressure with an 89 or higher octane ethanol / gasoline blend than you can with 87 octane gasoline. Also consider that I have been told that fuel blenders (E10) can use a low octane gasoline made from the heavier oil fractions which contain more BTU's than the lighter fractions used to make premium gasoline.
You can use a lower octane, yet higher BTU content gasoline to blend with ethanol which brings the octane level back to an acceptable number while gaining back a bit of those lost 3.5% BTU's.
I hate people using the fuel economy numbers taken from todays flex fuel cars. They are a terrible compromize, they have to be built to tolerate the lowest octane junk gasoline without detonation damage, usually well under 10/1 compression ratio which makes them very ill equipped to use the high octane properties of the ethanol / gasoline blends and especially E85. I don't know of any flex fuel car that uses an Atkinson cycle engine to take advantage of the higher octane ethanol blends, as their limited WOT power level is pretty bad on lower octane fuel without the help of a hybrid's electric motor boost.
