John Deere B tractor how do you get to the rod nuts
BlaineF
Got the B all apart ,but need to get at the rod nuts.Tractor is froze up tighter then a tick.Rusted cylinders and about 2 gallons of water in crank case.Where is the access hole to get at the rod nuts.Help is needed! This tractors a little more than I thought it would be.Going to have to press pistons out of cylinders.Thanks Guys
Yes, take the breather cover off of the crank case to get to the rod nuts and to clean out the crank case. With the pistons stuck it may be hard to get to the nuts if they are at the back of the stroke since the nuts will be close to the back wall of the crankcase.
Good Luck.
I used a combination wrench - I heated it and bent it to work.
Reminder = undo the oil line from the crankcase side before you take the block out.
