Chevy 3500 clutch master cylinder
TWL
Any of you have any experience changing out one of these? 2bolts hold it on and the control arm attaches to the clutch pedal,but how do i attach the hose to the reservoir?
Just try to pull the old one off and put on the new?Thank you for any help.
I dont know unless you describe it better.All I ever saw screwed into the cylinder like a brake line.If its different than that I dont know.
This is a 93 model.Plastic line and reservoir.It does not have any fittings,looks like a nipple on the bottom of the reservoir that the line just slides over.
IIRC the line just pushes into the cylinder to a certain point then a small roll pin pushes thru to the side and holds the line in.
Hey TWL, those are or used to be avail w or w/out reservoir. I suggest you spend the xtra 10 bucks and get the onede w. Only I could do it but managed to bust mine and strand myself @ the shop. JMHO fr
