Ford 2n engine knocking
Anonymous-0
I will keep it short hopefully. Tractor ran fine after a bit of bush-hogging. Shut off tried to start later and no luck. Had this problem intermittently before but usually got it start. Anyway the local folks i talked with advised a number of things to do. 3 of 4 said the coil was probably not the problem but that the points were probably fried. Replaced points and set the gap to .018 on advice of the older and wiser gents even though manual says .015. Put parts back in and then still no start. Talked to neighbor and he had a used front mount coil so what the heck...put it on and it started. However, I now have a loud knock. Motor has always ran smooth. Did I forget to do something while installing the distributer? I do notice in the book info on "basic timing" of the distributer but cannot make heads or tails of it so please humor me my friends. Thanks, Bill
Did you by any chance have the distributor off and in putting it back either loose a washer off a bolt or replace a bolt tht holds the distributor on? On a 9N that I have had developed a knock and was told it was a wrist pin, tore down and got all new sleves and pistons to put back together (still wating) and after everything I found on the timing gear just in back of the distributor where the small ribs are on the gear every one had a grove cut in from a too long of bolt having been put in to hold the distributor on before I got the tractor. 1/8" will cause that problem.
Thank you Leroy. I will look to make sure but pretty sure all parts accounted for and original bolts were used. Anything is possible though.
