IOWA NORTHEAST
The carb has been rebuilt, new gas tank, new fuel line, new sed bulb asembly. New plugs, and the front mound dist looks fine and we cleaned the points.
In order to remove the spark plugs, I had to pull the head, and heat two of the busted off spark plugs. When I did, there was absolutly no ring grove at all, so I would assume the valves were ground at the time it was overhauled.
It has a new battery (6) volt, but the starting is sluggish, it has new battery cables.
The thing ran like a million dollars till we put the belley mower on it a actualy gave it a work out. Now after twenty munites, it starts to miss to the point it can not power itself on the level in low gear.
The past three times we run it this has happened, but we always charged the battery prior to starting, I'm wondering if the battery is going dead, and shutting down the spark. I so far have not checked the coil, but I did pull a couple plugs in case they were fouling --to jump the spark--that did not help at all.
Now I'm wondering if the valves could be the issue? I'm sorry, I just haven't had time to mess with it like I should have to find the problem. Any other suggestions that I may be overlooking?
Thanks
