OT - Remoal of concrete from tiller?
TBprnaa
Any ideas on removing a large piece of concrete that wedged in large tiller? Will need to remove it at work in am. Lucky, slip clutch did its job but old piece of a building or slab (has wire / rebar in it)really stuck. Could not pry it out. Chisel & maul? Any ideas helpful. Thanks.
Heat will damage concrete. Put a torch to the chunk of concrete. My opinion it would be better for the tiller than pounding on it.
Thanks to all of you for good ideas. Will try to remove it in the morning. If tine(s) come off easily, one or two should free it. Old building / site materials left behind from demolition on a park site (several inches below surface). Chunk is wedged so tight I could not turn shaft, tines, etc. ThanKs again.
Tim
torch to a peice of concrete,..that's asking for trouble...sounds like someone trying out for the darwin award
Very dangerous to do exploding pieces can tear into flesh (been there when a co worker cut metal laying on the floor!! Not good. Jim
