brake adjusment on ford 850
histoman
New User
Could someone explain in detail how to make a brake adjustment on a Ford 850. I had new brakes installed about 10 years ago on my tractor that only gets about 20 hours of use per year. The brakes are not holding as well as they had been, and I believe they need adjusting. Thanks.
on the inside of the backing plate/shield assy there is a hole that has a metal clip in it it comes out and behind it is the brake adjusting screw reach in with a brake spoon or screw driver (flat blade) there is a star wheel turn clock wise or counter clock wise to adjust the brake hope this helps
