Hey Gary, I see there is a farm auction this Wednesday in your neck of the woods. Planning on going? I would go if it was about 500 miles closer!
Sale Bill
Tractors, Front End Loader, Skid Loaders —
1-1997 J.D. 8100 2 W.D. Dsl. Tractor, Duals, 1600 Actual Hrs.
1—1993 John Deere 7800 2 Wheel Drive Dsl. Tractor, Cab, A/C, Power/Quad Trans., 3 Pt., 2 Hyd., Wts., Quick Hitch, 18.4x42 Rubber, Axle Duals (8927 Hrs.) s.n.-2341
1–1992 John Deere 4955 M.F.W.D. Dsl. Tractor, Cab, A/C, P/S Trans., 3 Pt., 3 Hyd., Wts., Quick Hitch, Duals
1–1993 Case/IH 7130 M.F.W.D. Dsl. Tractor, Cab, A/C, 3 Pt., 3 Hyd., Wts., 18.4x46 Rubber
1–1979 John Deere 4440 Dsl. Tractor, Cab, A/C, Q/R. Trans., 3 Pt., 2 Hyd., Wts., 18.4x38 Rubber (8800 Hrs.) s.n. 17709
1–1993 Case/IH 7140 2 Wheel Drive Dsl. Tractor, Cab, A/C, 3 Pt., 3 Hyd., Wts., 18.4x46 Rubber
1–1978 John Deere 4440 Dsl. Tractor, Cab, A/C, Q/R Trans., 3 Pt., 2 Hyd., Wts., 18.4x38 Rubber (10,300 Hrs.) s.n.-1192
2–Sets 18.4x38 Axle Duals (For 4440) 1–Set Hubs
2–Boss 3 Pt. Quick Hitches, Cat. II To III
2–18.4x42 Tractor Tires (For Duals)
1–Great Bend 870 Hyd. Front End Loader, 8’ Bucket
1–2001 Case 1445 C Dsl. Skid Loader (2700 Hrs.)
1—2004 John Deere 328 Dsl.Skid Steer Loader (1500 Hrs.)
1–Case XL85 Dsl.Skid Steer Loader, Rubber Tires On Steel Tracts
Just Added - 1987 John Deere 4850 2 Wheel Drive Dsl. Tractor
Cotton Equipment–
1–McElroy 32’ Cotton Module Builder, Cab, s.n.-HFS100-88-027
1–Big 12 Single Dump T.A. Boll Buggy
1–1982 John Deere 484 4 Row Dsl. Cctton Stripper, Cab (4080 Hrs.) s.n.-1797
Truck Tractor, Grain Trailers, Hay Float Trailer –
1–1986 Freightliner Cabover T.A. Truck Tractor, Sleeper, 3406 B Cat. Engine, 13 Spd Trans.
1–1974 Wilson 40’ Hopper Bottom T.A. Aluminum Grain Trailer, R/O Tarp
1–1972 Timpte 38’ Hopper Bottom T.A. Steel Grain Trailer, R/O Tarp
1–1994 Transcraft 52’ Float Flatbed T.A. Trailer (Used For Hay)
Just Added - 1997 Freightliner Classic T.A. Truck Tractor, Sleeper, Cat 3406E Dsl. Engine, 500 H.P., 10 Speed Trans.
Hay Equipment–
1–Hesston 4900 4’x’4’x8’ Big Suare Baler w/Accumulator
Pick-ups–
1–2000 Toyota Extended Cab Pick-up, 4 Cylinder, 5 Spd.
1–1989 Toyota Pick-up, 4 Cylinder, 5 Spd. Trans.
1–1989 Chevrolet 1500 1⁄2 Ton Single Cab Pick-up, V-8, A/T
1—1984 Toyota Long Bed Pick-up, 4 Cylinder Engine, 5 Spd. Trans. (Needs Engine O/H)
11981 Isuzu Mini Pick-up, 4 Cylinder, 5 Spd. Trans. (Needs Engine O/H)
Cotton Trailers –
1–Big 12 24’ Metal Flatbed Trailer
4–Big 12 20’ Metal & Wirte Cotton Trailer
2–Big 12 20’ Metal Flatbed Trailers
1–John Deere 20’ Metal Cotton Trailer
2–Light Systems For Cotton Trailers
Farm Equipment–
1–Case-IH 900 3 Pt. 8 Row 38”Planter, Monitor, Big Big Bar
2–John Deere 7100 12 Row 30’ 3 Pt. Planters, Plateless, Double Boxes, 1–With Markers
1–Roll-A-Cone 3 Pt. 8 Row 38” Disc Bedder, D.S.B., L.T.M., Stabilizer/Coulters. G.W. w/RAC Hyd. Flat Fold Row Markers
1–Sam Stevens 3 Pt. 8 Row 38” Double/Stanted Gang Stalkcutter, Double Big Bar
1–Lilliston 3 Pt. 8 Row 38” Rolling Cultivator, Big Bar
1–3 Pt. 8 Row 38” Hyd. Rodweeder Rig, 4”x7” Bar, G.W., Cleanouts
1–John Deere 400 3 Pt. 28’ Rotary Hoe
1–John Deere 400 3 Pt. 26’ Rotary Hoe
1–John Deere 400 3 Pt. 20’ Rotary Hoe
1–Roll-A-Cone 3 Pt. 8 Row 38” Middle Runner w/Paddle Dikers (5), D.S.B., G.W.
1–Hamby 3 Pt. 8 Row 38” A.A. Fertilizer Rig, T.S.B., Notrolator, T.P. Hitch
1–International 140 3 Pt. 4 Bottom Spinner Mouldboard
1–Caldwell D.T. 14’ Shredder
1–International 480 D.T. 21’ F.W. Tandem Disk
1–Big Ox 3 Pt. 8’ Blade, C.C.
1–P & W 6 Row 38” Cleanout/Water Furrow Rig, G.W., 4”x7” Bar, Single Diamond Bar Behind
1–S & S 3 Pt. 20’ Spring Shank Field Cultivator w/Lift Harrows
1–S & S 3 Pt. 17 Shank Chisel/Sweep Plow, T.S.B., D.G.W.
1–Krause D.T. 14’ Tandem Disk
1–John Deere BW D.T. 14’ Tandem Disk
1–Herd Seed Broadcaster, F.M. Bracket
1–Graham D.T. 10’ Hoeme, C.C.
1–Moline D.T. 16-10” Grain Drill, S.D. (Galv. Box)
1–John Deere RW D.T. 8’ Tandem Disk, C.C.
1–John Deere 3 Pt. 5 Row 38” Lister, D.T.B. (Diamond), G.W.
1–3 Pt. 6 Row Rolling Cultivator, Small Bar
1–John Deere D.T. 18’ Single Gang Disk
1–John Deere 825 3 Pt. 3 Bottom Spinner Mouldboard
1–10’x20’ Land Float
1–3 Pt. 5 Row Sweep Plow, S.T.B.
1–John Deere 3 Pt. 6’ Blade
1–Phares Wilkins 3 Pt. Disc Ditch Filler
1–2 Row 3 Pt. Knife Sled
1–3 Pt. V-Ditcher
Spray Equipment, Trailers, Tanks–
1–Red Ball 420 3 Pt. 8 Row 38” Hooded Sprayer, 300 Gallon Poly Tank, Hyd. Fold
3–Lee 3 Wheel Spider Sprayers (2–w/Gas Engines, 1–Less Motor, Hand Sprayers)
1–3 Pt. 16 Row 38” Hyd. Flat Fold Spray Boom
1–Front Mount 200 Gallon Spray Rig w/Ace Pump
1–Jayco Pop Up Camp Trailer
1–2 Wheel Pickup Bed Trailer
1–MW 4 Wheel Trailer Chassis
1–1000 Gallon S.A. Water Nurse Rig
1–500 Gallon Diesel Trailer, 12 Volt Pump
1–500 Gallon Propane Tank, 200 PSI w/Filler Hose
1–350 Gallon S.A. Fuel Tank/Trailer w/12 Volt Pump
Irrigation –
1–Chrysler Straight 8 Well Motor w/Original Shields & Radiator
9–Salvage Irrigation Motors
1–BCI 15 H.P. Rotophase (Good)
1–7 H.P. Booster Motor (Good)
40–Jts. 7”x30’ Aluminum Flowline
5–Jts. 8”x30’ Aluminum Flowline
70–Jts. 7”x20’ Aluminum Gated Pipe, 38” Rows
20–Jts. 6”x20’ Aluminum Gated Pipe, 38” Rows
1–Lot Aluminum Irrigation Tubes, 3”, 2”, 11⁄2”, 1”
4–7” & 8” Solar Surges
12–Irrigation Hydrants, 10”x8”, 10”x7”
1–Lot 7” & 8” Tees 1–Lot 6”, 7” 8” Adaptors
1–Lot Slip Joints 1–Lot Short Joints
1–Lot Risers, Alfalfa Valves
1–30’ 2 Wheel Pipe Trailer
Toolbar Make-ups–
6–John Deere Orchard Shanks
5–John Deere Lister Shanks
2–Roll-A-Cone Stabilizer/Coulters
1–6 Row 12” Bed Roller
2—Weight Brackets 1–Lot J.D. Rotary Hoe Wheels
1–Lot Busters, Sweeps 1–Lot Shanks, 1”x3”
1–Lot Clamps, 1”x3” 1–Lot Knives
1–Lot Imp. Wheels, 6 Hole
12–Chemical Boxes For 900 Planter
2–Furrow Guides
Shop Equipment, Mobile Washer, Non-Classified -
1–Lincoln 225 Electric Welder
1–Cutting Torch 1–2 Wheel Bottle Cart
1–Shop Vise
1—2005 Mobile Car Wash w/Trailer, Pump, Gas Engine
1–Lot Scrap Iron, Old Implements
Springlake Farm Auction 12/15/2010
Sale Bill
Cotton Equipment–
Hay Equipment–
Pick-ups–
Cotton Trailers –
Farm Equipment–
1–3 Pt. V-Ditcher
Irrigation –
Toolbar Make-ups–
2–Furrow Guides
1–Shop Vise
