Our tractors
CBL95
two of our 21 tractors a 1974 AC 200 formerly owned by the late chairman of the board of the NFO Glenn Utley at Gibson Southern FFA tillage day 2010 pulling a Chem-Farm 7 shank chisel plow. the second is a 1959 jd 730lp that is kind of my baby if anybody is knowledable about these please e-mail me i am havingg trouble keeping it running. Thanks cort
I have a 630 LP that I have for sale right now..
Have you checked the fuel screen (solenoid) to see if it needs cleaned..?
The vapor generator could be gummed-up and need dis-assembling, or the diaphragm could be going bad..
I found a lot of gum in the tube between the vapor generator and the carburetor too..
I took the carb off and cleaned it really well..pretty simple carb too..!
I am not any expert on the LP and can't help you much..!!
How long have you had the 730 LP..??
Ron..
Some days it will be easy to start but some it wont start for anything i cleaned to vaporizer and solnoid but have not checked the hoses from the tank if it starts it will run for 20 or 30 min. then quit and after i charge the battery it starts and repeats
I'm no L.P. expert, but it sounds to me like it's an electrical issue. If you charge the battery and it'll run for 20-30 minutes then die, that would tell me that your generator isn't charging, which means the battery is going dead and shutting down the solenoid. Also would explain why it won't start sometimes, as not enough current in batteries to open solenoid. Just my thoughts, again not an L.P. expert...
Neighbors and good friends at farm used A-C for years. I think they had a 190 with a cab. He still has his Dad's WD-45 and D-17. Your 200 is really sharp, those ACs, the 66 series IH, 4020 JDs, Oliver 1800s and Case Comfort Kings (930, 1030) are what tractors ought and should be. Rugged, reliable, servicable.
i agree complety i dont think i would trade that tractor for anything we are only the second owner of the tractor and my great uncle bought it new and used it a 57 JD 520 and 7060 and an F2 gleaner on his 400 acres and until we bought everything but the 7060 in 1999 they hadent been more than 5 miles from the home place
