How much am I looking at?
CBL95
Im looking at restoring our Super MV for my junior and senior FFA project. I think the engine in ok, we tried to rebuild it but when we put it back together it wont turn for some reason. the clutch,tranny,hyd everything else is good and have everything for it. how much am i looking at pricewise to restore it. (paint,guages,decales,etc)
I realize that some of it depends on whats wrong with the engine.
God Bless,
Cort B. Lamey
What did you use to tighten the main bearing caps
and connecting rod caps? Are the numbers on the caps facing toward the cam? I would loosen all the caps then see if you can rotate the engine. Hal
Be sure you have not switch position of the main bearing caps on the block. They MUST go back where they were originally positioned. Also you CAN NOT switch the rod caps around on the rods.
Kent
it depends on your definition of restore. restoration is replacing pretty much everything with new parts ...bearings seals gaskets tires engine internals ( already done in your case) and paint. if you don't have a means of media blasting by yourself and having the proper paint equipment it is pretty expensive. several 1000 dollars. The good news is the super MV is a pretty rare tractor to a collector and you possibly could get your money back out of it if you needed to.
