Making light lens clear again?
Mitch D
Still slowly plugging away at the D and am to the lights. They are the big 7 inchers, two have original lens and one is new. Anybody know how to get them old ones cleaned up some and get that yellow orangy tint out of them? Not going to buy two more new ones but it would be great to clean these.
Thanks Mitch
I have had good luck with cleaning paint and crud from lenses by rubbing them with a healthy gob of GOJO hand cleaner, takes about two or three minutes of rubbing but it seems to always come clean.
I"ve had decent luck buffing lights and mirrors out with either rubbing or polishing compound. I like the Turtle Wax brand. Seems to take the crud off like right now.
if theres someone there that has a SODA BLASTER ... soda will remove the stain and not hurt the glass ..
I know because I have done it .. it { soda } will take paint off of CHROME ..with out hurting the Chrome ...
Mark
There's a product at certain auto parts stores that is designed to use for these "clouded" lenses. Don't know what it's called---I just happened to notice it on the counter.
Told my wife to check out, not buy, the hit at the store. She came home with a 3M kit that had the samd paper, it is going back, not putting sandpaper on my plastic headlights in the car. Took to a local mechanic and he used just plain old body buffing compound and you can realy see the difference.
I have my doubts about glass polishing with the compound for plastic lenses.
Leroy, I didn't buy a kit, just the polishing compound.
I watched a video on plastic headlight lens polishing and proceeded from there. I first tried the compound alone and quickly realized that wouldn't do the job alone, so I did use sandpaper of 2000 grit---after ones of coarser grit.
I think you will need to use more than the polishing compound if your lenses are pitted and clouded very badly.
You might get by with the compound only if you use power tools, I did all of the work by hand rubbing.
Before and after photos but want to say it was very windy so I spent little time instead of doing a thorough job. I thought I had a composite photo showing the two side by side but don't.
http://i163.photobucket.com/albums/t298/growerguy/002.jpg
http://i163.photobucket.com/albums/t298/growerguy/003.jpg
After
