switchzer ford 9700 turbo
does anybody no where to get parts a for a ford 9700 switcher turbo or no anybody that sells parts or rebuilds them. im looking for the little brass paice inside because the blades inside are starting to wobble. went to new hooland todya and they said that was all it needs. i need to find 1. thanks for the help and leads.
Why didn't you check to see if dealer had one...or could order it for you. Seems to me that would be a lot easier/faster than scrounging all over. My 2cents.
i put in my statement that i did go to the new holland dealer today. they said they are obsolete and they cant get them. somehow they must be available beause how would somebody rbuild your old 1.
MANY local diesel injection equipment shops rebuild turbos.
Any near you to check with?
well there is a place in lowville about 25 mins form me hat rebuilt my 6610 motor and they rebuild injector pumps also but im not sure if they do turbos. i could probably call them.
Look in the yellow pages for diesel/injection/turbo shops. They'll no doubt rebuild it for you or supply you a center kit and you change the housings.
Rod
There is a place in Grand Rapids Michigan called Michigan Turbo. They should be able to get you whatever you need.
http://www.michiganturbo.com/turbochargers.nxg
