You can probably find one cheaper but it won't likely be as good a quality as the one from LMC. I don't know how much the ones for your Ford are at LMC but I think the one for the extended cab of my '98 Chevy was around $50 which I didn't think was all that bad. It fit so well you can't even tell it's been replaced. Maybe just beginner's luck, I don't know.
Might try Mills Supply in Cleveland, or Sioux Plating in Sioux City. But don't plan on finding them cheaper than LMC.
I work with repair panels all the time and, like everything else, any panels worth buying will be competively priced between suppliers.
I have a New Ford Part Here at the store
However I don't know if it's a regular cab
'or super cab.... The one I'm Hung with is a
Left Hand.. A new Ford Part runs clear to the
roof.. I can make you a deal on it if you
Like...
RLA
Mark,
I am a Ford Parts Manager the Part # I have
is a E4TZ15280A59A replaced on up to E7TZ15
280a59A & then to a F3TZ15280A59A. So really
this part in the Same from 1984 to 1996. As
long as U have a Regular Cab. Now Ford Motor
felt this part was Worth 459.88, reason being
it's now no Longer serviced, & when Ford
Obsoletes a part they inflate the price for
tax purpose's.. & We both know thats B/S!
The is 53" long from the roof joint to the
rocker panel. If ya measure to the seem where
it meets the back cab panel it's 15" wide..
This is Only the Outer Skin, no inner door post
connected to it.. I would take 35.00 for it
+ any UPS Charges..
This part is For a Regular cab, Not a Super
Cab & it's Left Side...
Randy
I don't have my camera today at work but I
can take one & email it to ya Tomorrow..
As for posting a Picture on here I don't know
how..
Again Mark, I do know what I'm doing when it
comes to Ford Parts.. But what YOU HAVE NOT SAID
Is whether you need a RH Part a LH Part If your
truck is a REGULAR CAB or a SUPER CAB.. A cab
corner is a Cab Corner whether it's a 1950 or
2011, Behind the Door, wraps around the rear
corner of the cab. I will need a Email..
