Rear tire pressure
jrw
New User
I have 16.9-38 rear tires and can not find the tire pressure rating anywhere. Yall have any ideas?
Inflation at maximum load for bias tires is 18# for 6 ply, and 24# for 8 ply per Firestone website.
Do a search for Firestone Ag tires. All the info you could ever want.
16.9X38 tires. That is saying you wear 34" waist pants and expecting us to know what you look like.
Radial, bias, road travel, soil type, heavy draft equipment, loader, type and amount of ballast, tractor static weight, tractor HP, tread bar design and bar height?
(quoted from post at 04:02:47 04/20/11) 16.9X38 tires. That is saying you wear 34" waist pants and expecting us to know what you look like.
Wouldn't it have been easier to just not type anythingh or type "I don't know" ?
Just when you get tolerable, your people skills shine thru.................
(quoted from post at 04:09:12 04/20/11) How would you know about people skills when living
with Germans and active military personal?
you don't have the courage or qualifications to comment on soldiers so just leave them out. Some of the germans have about the same personality as you so comment away.
Arrogance is very unbecoming your Canadian ancestry must weigh heavy on the french side.......
Now, keep quiet and let the guy get his tire pressure answer.
Dave
Does that include the group of soldiers that stole from you to build an unapproved project?
As to courage and honour of military personal? They vary from the very best to the most vile in society.
So how exactly is it my fault when somebody wants an accurate answer yet they do not provide relevant data?
It really doesnt matter, he just wants to know what the rating in psi of the tire is,Load is not so much of an issue on a tire because there is a min and max of psi you can run in a certain tire of a certain size. And actually from a 34in waist size you can tell alot about a person as far as height and weight.
(quoted from post at 18:37:15 04/20/11) It really doesnt matter, he just wants to know what the rating in psi of the tire is,Load is not so much of an issue on a tire because there is a min and max of psi you can run in a certain tire of a certain size. And actually from a 34in waist size you can tell alot about a person as far as height and weight.
Somewhere between 4"6" and 6'8" and ranging from 125 to 275lbs.
That is a best a "seat of the pants" estimate.
(quoted from post at 20:19:11 04/20/11)
b&d
I've seen anyone as short as 4"6". Do they have a lot of French ancestry?
