Farmall Tractors Discussion Board
Re: Polarizing a generator for 12v lo-boy
Posted by JW on January 27, 1999 at 12:00:27:
In Reply to: Polarizing a generator for 12v lo-boy posted by Scott on January 27, 1999 at 08:15:01:
After new regulator has been installed and grounded, connect cables to the battery again, before starting engine you,
must polarize the generator to match battery.
Momentarily touch one end of a piece of wire (your supply) to regulator terminal marked "arm" or "gen" and the other end of
that piece of wire to the terminal marked "bat" then remove. A spark will occur when wire is removed. This is natural.
HOWEVER, DO NOT TOUCH "FLD" TERMINAL. IF YOU DO, THE REGULATOR WILL BE INSTANTLY RUINED.
Hope this helps.
Post a Followup
: Re: Re: Polarizing a generator for 12v lo-boy
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
