Farmall Tractors Discussion Board
Re: Re: MAX RPM
Posted by john d. on January 28, 1999 at 07:36:32:
In Reply to: Re: MAX RPM posted by mjdelaney on January 28, 1999 at 05:24:39:
For a job that uses the pto as you describe, steady rpms at rated speed is what you want. using the pto to set it will work just fine. Put a tach on the pto shaft, and mess with the governor to get the speed you want. You can run it with the governor cover off if you don't mind a little oil spray, or put the cover on with two bolts finger-tight. Most pto-driven machines will run at maximum efficiency at the 540 rpm that's standard for these machines. Some, such as a combine, MUST run at this speed or they simply won't work as planned! Additional engine rpms are useful on some tasks, such as tillage, where a little more speed gets the job done sooner. I always felt additional rpms had no bad effect when pulling a forage chopper. The chopper didn't seem to mind, and the wagons filled faster.
In terms of maximum power or efficiency.... well, things get a little murky here. The engine will run at standard rated rpms and last about forever while delivering close to advertised horsepower, but generally, most engines will deliver more power if run faster, (up to where they can't breathe, or where the reciprocating parts can't start and stop fast enough!) because POWER is the RATE at which work is done. If two tractors do the same job, but one does it faster, it's generating more power. Lots of these older tractors have been adjusted to run much faster than stock rpms because someone wanted the work done sooner.
Post a Followup
: Re: Re: Re: MAX RPM
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
