Farmall Tractors Discussion Board
Re: TD-6 Talk
Posted by JW on January 28, 1999 at 09:24:52:
In Reply to: TD-6 Talk posted by Dan on January 28, 1999 at 05:47:58:
The td-6 has the same engine as an MD. It starts on gas then you switch it to diesel. The engine should have both a distributor and an injection pump. They are however on opposite sides of the engine. The injection pump will be an inline pump. It is an IH engine, which is used in a MD, WD-6, ID-6, OD-6, and a Ud-6 stationary engine. I don't have a serial # book handy, so I can't help with aging it. If it does not run, the head should be checked for cracks. That is very common to see cracked heads on the gas start diesel run engines. I hope this helps you a little.
JW
Post a Followup
: Re: Re: TD-6 Talk
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
