Found where the tapered bolt came from
Posted by Joe Berendzen on February 04, 2001 at 18:30:37 from (216.152.11.97):
I got the liftall pump out from my SM today, and found that the tapered bolt I found last weekend did come from the clutch shaft coupling as suggested by one of you fine gents.I also found that the release sleeve carrier was broken from both mounting bolts. This part appears to be cast aluminum. I guess I'll call my friendly dealer tomorrow to see if it's still available. If not, I'll have to make a trip to the boneyard.
I had to remove the liftall by myself, so I welded a 1/2 x 2 x 4 plate with a 3/4 inch hole to the top of my floor jack and put it under the liftall, between the two holes for the Tee handles shown in the book. I put a 3/4 inch rod through the two holes with the plate in between to link it together, and it lowered down without a problem.
Post A Followup
: Re: Found where the tapered bolt came from
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
