Re: Removing Pistons Question!
Posted by scott m on February 05, 2001 at 19:07:09 from (216.89.117.237):
In Reply to: Removing Pistons Question! posted by Scott S. on February 05, 2001 at 09:32:57:
rebuilding an h is not a great big feat. just trash the pistons and sleaves if they are that bad, it just make sense to put that much work in something that will just eat up a new set of rings. use a piece of 3/8 x 1" flat bar to pound the pistons out from the bottom you will be able to slide it next to the connecting rod so that you beat on the bottom of the top of the piston,that will get them out without any damage to the rod. if you take the input shaft of at the flex joint you will be able to crack the tractor without having to remove the clutch and pressure plate. if you check the size of the journal on the crank you should be able to tell if you need bearings, they make bearings that are -.002 if your crank has some wear on it. when i bought my engine rebuild kit it came with everything i needed to do a total overhaul,
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
