Re: determining voltage
Posted by Bob M on February 19, 2001 at 18:57:58 from (66.66.72.246):
In Reply to: determining voltage posted by joe on February 19, 2001 at 18:35:17:
Can determine voltage several ways: If the electrical system has only a cutout (usually mounted right on the generator) and no regulator, it's 6 volts. If you've got a voltage regulator, often the regulator voltage (and sometimes polarity) will be marked on the cover. Or if you've got headlights, pull one and look at lamp - voltage will be marked, or can be crossed from the lamp number. If you've got an alternator 12 volts is virtually assured. If all the above fails, you can fire the motor, and you have a voltmeter, try this: Run the motor at 1/2 throttle and measure the voltage across the battery cables. About 10 volts or lower means 6 volt system, 14 or higher says it's 12 volts. Ground polarity can be determined by hooking up a battery then turning on an electrical load (lights or ignition) without starting the motor. If the ammeter deflects toward "-", you've the battery ground polarity correct. If it reads "+", you've got it backward. Finally if you have an alternator, it WILL be negative ground.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
