F400 Governor Problem
Posted by Larry(SD) on February 22, 2001 at 19:02:38 from (208.164.249.22):
I have a F400 that appears to have governor problems when cold outside (>20F).
The engine will not throttle down. This occurs even if the tractor is allowed to warm at idle.
Warming the engine with a forced air heater seems to help. I now do this prior to starting the tractor. However, if I shut it down and restart later (+30 minutes), the engine will not throttle down.
The oil (use CaseIH #1) within the governor housing is sometimes milky. I cleaned the housing with WD40 (plugged gallery to minimize drain back when spraying WD40) thinking moisture was the problem. This had no apparent affect as the problem reappeared.
The throttle linkage appears okay. I do note a moderate dead band beginning at approximately the mid throttle position.
Any help would be appreciated. Note that I am somewhat intimidated by the governor and carburetor.
Post A Followup
: Re: F400 Governor Problem
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
