Re: MD Wire Harness question
Posted by Haas on February 26, 2001 at 06:21:46 from (129.37.117.6):
In Reply to: MD Wire Harness question posted by Ike in NC on February 25, 2001 at 17:11:26:
If you have a "regulator" mounted on the radiator, likely someone has changed things around, because that is not where it was originally. I think a 52 MD would have had a regulator and not the cut out. The wiring on the MD is not all that complicated and I don't think you need to bother with a harness. Just go to a generator shop and get a new regulator and mount it same place the old one is. Make sure the shop knows it is for a 3 brush generator. Then you run two wires to the generator, one to "field" and one to "Gen"(or armature) terminal. Then run one wire from the "Bat" terminal on the regulator to the ammeter. If the regulator has an "L" terminal, that is for "load" or "lights" and does not need to be connected to anything. The other side of the ammeter should go to the battery. It may be just connect to the starter switch on the battery side. Then polarize the generator by jumping a wire momentarily from the armature(or may be called gen) terminal to the battery terminal on the regulator. If you buy a new regulator there should be a paper in the box explaining all this. Be carefull not to short out any terminals or ground anything accidently or you can ruin the regulator or the gen or both. Since there is only one wire to run from the regulator to the ammeter, it's not really worth a wiring harness. This is what I did to my MD and it works fine. I used two 6 volt batteries on mine connected in series just like they came originally. Post a picture of your MD if you can, I would like to see it. Good luck! I have the instruction sheet from my regulator and could scan and Email to you if you want.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
