Re: Re: What makes a gas engine run rich
Posted by Gene on March 02, 2001 at 21:52:45 from (205.188.200.156):
In Reply to: Re: What makes a gas engine run rich posted by dick on March 02, 2001 at 18:58:59:
I certainly appreciate the feedback. Your list of possibilities sparked a few new ideas. Here is a list of what I have done so far. -Had carb overhauled and flow tested twice. -Checked the float level in carb with external hose while tractor was running. Found to be OK. -Changed out the fuel pump and checked fuel pressure. -Put in hotter plugs. Running D21's currently. -Replaced the coil, condenser, points, distributor cap, plug wires, and coil wire. -Set the timing and checked centrifugal advance. -Ran carb without air intake hooked up and also checked air intake and filter replaced. -Went from unleaded regular fuel to super premium unleaded fuel. -Cleaned fuel line, filter and bowl. -Disconnected and blew out fuel line with compressed air. -Checked compression on engine. Found to average about 160 + or - about 8 lbs. -Put in a lead additive to a tank of fuel and tried that. May have forgotten some items. If it is of any help, the tractor runs richest at slow idle, and will almost choke you with fumes from unburned gas. When the tractor is run hard with a load, it seems to do better. Has plenty power and doesn't miss. But, when plugs start to foul out, the miss returns. Solution, pull the plugs, sandblast them or replace them, and problem goes away for a little while. But, I haven't really checked to see how "strong" the spark is, and the intake manifold could be a problem I guess. I have sprayed around the manifold with WD-40 to see if I could detect any change in engine sound, but nothing happened. Again, thanks for the list you provided me. Any thoughts are appreciated.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
