Re: Re: W-9 no fire
Posted by Andy Martin on March 04, 2001 at 12:30:22 from (38.31.74.43):
In Reply to: Re: W-9 no fire posted by Red power specialist on March 03, 2001 at 18:07:07:
Run the hot wire from the ignition switch to the - connection on the coil. The other connection(+) should go to the distributor. These two connections are each end of a coil of wire in the "coil". To check the coil, hook a spark plug up to the big wire coming from the coil and ground the threaded part of the spark plug. Then ground the wire going to the distributor momentarily. Whe you remove the ground you should see a spark across the plug gap. The coil makes a spark when the current through it is interrupted. Buying a new coil is senseless unless the old one is bad, and they are easy to check. A bad looking wire from the coil to distributor also may be OK but is cheap to replace. If you have put in new points and adjusted them properly, unhook the condenser, even if it is new it may be bad. You will still get a spark with the condenser unhooked. After you get a spark from the main coil wire, you can trace the problem through the rotor and cap if it still exists. Do start with new spark plugs. Good ones go bad sitting sometimes.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
