Re: Super AV Steering Pipe Plug Won't Stay Tight
Posted by Haas on March 05, 2001 at 18:57:52 from (129.37.117.214):
In Reply to: Super AV Steering Pipe Plug Won't Stay Tight posted by Phil on March 05, 2001 at 17:53:36:
Sounds like you have the washer interfering with the ball bearing that takes the thrust from the worm gear. If you put a washer in there, it has to have a hole big enough to not contact the inner bearing race or the nut that holds the bearing in. Or did you put the washer under the castle nut that holds the bearing in?? That would be the place to put it. In that case, the washer must contact only the inner race of the bearing. If everything is right, you should be able to tighten the big pipe plug up real tight and it should not affect the steering. Don't know much about the AV, but I guess the steering box is the same as the Super A. I think you need to take the worm gear out and put you a new ball bearing in. It is probably worn, causing your steering play. If it is like the Super A, take off the steering wheel, take the plug out of the steering gear and then screw out the worm gear. You will see the bearing held on the end with a castle nut and a cotter pin. Go get a new bearing (the bearing costs less than $10) and put it on there. If the castle nut does not tighten the bearing tight against the worm gear, put a washer under the castle nut, but make sure the washer contacts only the inner race and not the outer.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
