Re: H hyd. lift.
Posted by Haas on March 24, 2001 at 12:36:42 from (129.37.117.123):
In Reply to: H hyd. lift. posted by Whiskers on March 24, 2001 at 09:23:01:
You can put a one way restrictor in the hydraulic line. It will not restrict the flow to the cylinder, but the flow rate back out of the cylinder will be adjustable. You can get one from Northern Tool. I suppose a place like Tractor Supply might have them too. It's real hard to let the lift all down slow with out some kind or restricter. Another option is to get a spool valve that will allow you to control the cylinder as a two way cylinder instead of one way. That is going to be a lot more expensive and will require quite a bit of piping and hose. You have to run the return from the spool valve back to the fill pipe on the lift all. In addition, there would be a hose from the liftall outlet to the spool valve and two hoses from the spool valve, one to each end of the cylinder. With the spool valve system, you have to lock the lift all in the lift position when ever you are using the spool valve.
Post A Followup
: Re: Re: H hyd. lift.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
