Pin in water pump assembly
Posted by BTD on April 05, 2001 at 06:24:34 from (207.48.192.3):
I've read before that I need to remove the pin from the bracket at the front of my water pump assembly to get the thing apart. I have the nut off, but the pin will not budge. It does not look at all corroded and I have let so much PB-Blaster soak around the pin that it drips out by the large brass? nut behind the bracket. Should it be that hard to remove this pin? Thanks! -BTD
Post A Followup
: Re: Pin in water pump assembly
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
