C front transmission seal
Posted by Haas on April 09, 2001 at 19:05:57 from (129.37.117.72):
I have a fairly significant oil leak coming out at the rear of the clutch housing where it bolts to the transmission case. I suppose it is the shaft seal on the transmission drive shaft. I note from the parts catalog that there is a coupling in the drive shaft just in front of the transmission. You can see the coupling through the hole in the bottom. I'm wondering what the procedure is to change the transmission shaft seal. Can it be done without splitting the tractor?? If the tractor has to be split, do you do it at the clutch and then remove the clutch housing from the transmission or can you split it in front of the transmission to make the repairs?
Post A Followup
: Re: C front transmission seal
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
