Re: M /H fan belt ajustment
Posted by The Red on April 16, 2001 at 05:06:57 from (12.75.196.253):
In Reply to: M /H fan belt ajustment posted by will on April 16, 2001 at 03:16:09:
Will make sure your radiator tubes are not packed with dirt on the outside. It sounds like you are not getting good airflow through the radiator. Those belts can be quite loose and should not make a difference in the temperature. I usually tighten them so there is about 1/2' play when you push on the side of the belt. Don't get them too tight or you will be putting unnecessary pressure on the water pump hub bearings.
Post A Followup
: Re: Re: M /H fan belt ajustment
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
