Re: Leaking Steering Box on C
Posted by Haas on April 18, 2001 at 18:25:17 from (129.37.117.216):
In Reply to: Leaking Steering Box on C posted by FC on April 18, 2001 at 11:42:08:
Replacing the seal on the steering shaft is pretty easy. If it is the seal on the pedestal that supports the front wheels, it's a bigger job. To replace the seal on the steering shaft: - Take the grill off - Take the steering shaft loose from the steering gear shaft by removing the roll pin that goes through the universal joint and the steering gear shaft and then sliding the universal joint off the shaft. You probably will have to take the bearing (clamp)loose that holds the steering shaft to the clutch housing. -make sure to get the half moon key out of the steering gear shaft before you try to remove the shaft. - Drain the oil out of the steering gear - take a big wrench and unscrew the large plug on the front of the steering gear. - You can then screw out the worm gear together with the thrust bearing that is on the end. -now you can easily pop out the old seal and press in a new one. And then put things back together. While you have the worm gear out, check the ball bearing. If it has any play in it, replace it too while you have it out. Play in that bearing is a source of play in the steering. The bearing costs less than $10. Good luck. If you have to replace the pedestal shaft seal, you will need to remove the radiator and the entire front bolster. It requires a bearing press to get things apart to replace that seal.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
