Re: ONE H OF A TIME with H Brakes
Posted by Farmer Bob on April 19, 2001 at 20:54:07 from (208.49.9.232):
In Reply to: ONE H OF A TIME with H Brakes posted by Michael Soldan on April 19, 2001 at 18:44:40:
Mike, There should be a large metal washer and then a leather washer under the nut on the center of the drum. Once you get those off encourage the drum to come off the splined shaft of the bullpinion. This should allow you enough room to start surgery on the old seals. Most likely you will find the old style double leather/spring seals in there. Others recommend drilling a few holes in the face of the old seals to get a prybar/screwdriver in there to start ripping away the old seal. I have had good luck with a seal puller and using the outer housing as a fulcrum to wrench the old seal out. They can be stubborn so be patient. Be careful using things like chisels and such that are hard as that is a cast housing and you can nick it real easy. Tell mamma you would like lunch in the shop as it may take awhile to accomplish the job. I recommend installing two new seals on each side as they are about half as thick as the old ones. You can position them so they will rub on different places on the inner drum housing than the original seal rode. This should eliminate the need for speedy sleeves which are quite spendy for that large a diameter/depth. After you get the old seals out check those large bearings behind the seal for slop/wear/missing balls. If you have to replace them they run about $45-50 ea from Case/IH dealer. Bearing supply houses may be cheaper.Good luck.//FB
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
