Re: clutch housing on farmall H
Posted by Theman on April 26, 2001 at 05:36:33 from (204.149.23.2):
In Reply to: clutch housing on farmall H posted by Jim Dowie on April 26, 2001 at 04:38:35:
To remove the housing from the transmission there are six bolts and two threaded dowel pins. The dowels are located between the pairs of bolts you remove from inside the housing. Take them out first. Put a nut on the threaded part and it will pull the pin as you turn the nut against the casting. These are longer than the dowels in the front (engine) end of the housing so you may need to add washers under the nut when you run out of threads. I hope yours are in better shape than mine. A previous owner had let something like wire wrap around the input shaft at one time and the dowel threads were partly gone. A nut wouldn't go on it so I had to pry things apart. Also, I don't know if you have the engine off of the housing yet but in order to pull the engine off of the front, you have to remove the starter to access a cap screw that goes into the block. It would be a good idea to strip the housing as much as possible before separating everything. Remove the belly pump and take the clutch pedal spring loose. If you plan to use a hoist, you don't have to remove the u-joint looking yoke and clutch shaft. It can stay with the transmission input shaft while you move the housing forward. Above all, be careful. Use your brain before you use your back and you'll preserve them both. All of these parts are bulky and gravity has an affinity for them.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
