Re: Re: Farmall M hydraulics
Posted by Haas on May 12, 2001 at 07:14:17 from (64.12.105.32):
In Reply to: Re: Farmall M hydraulics posted by KURT on May 12, 2001 at 05:20:20:
Kurt, that will not work on the lift all on the M. The lift all is a single acting system. All three of the ports are pressure ports. There are three positions on the control rod. Lift is when the rod is pulled all the way back. Hold is when the bump on the rod is resting against the support. Drop or release is when the rod is all the way in. The weight of the implement pushes the hydraulic fluid back into the reservoir. You can vent one side of your double acting cylinder and lift, but not put down pressure. If you want to use a double acting cylinder, you can add a two way spool valve and run the return into the fill port on the lift all. To use it that way, you lock the lift all rod in the lift position so it pumps through the spool valve all the time and usse the spool valve to control your cylinder.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
