Super H steering mechanism - need help!
Posted by Bob M on May 12, 2001 at 18:39:37 from (66.66.72.246):
Got the bolster pivot shaft, etc removed on my Super H this afternoon in order to replace worn bushings in the steering mechanism. When I got it apart I discovered the bushings indeed need replacement. However I found the thrust bearing to be in perfect condition. Reason for this was a previous owner had put it together wrong, leaving out the "upper bolster pivot shaft thrust bearing spacer" part # 67 836 D. This resulted in the weight on the front wheels being carried by the flange and bolt heads at the bottom of the pivot shaft instead of by the thrust bearing, hence the thrust bearing's condition being "like new"!
My question is this: Anyone know the thickness of the missing spacer? In the parts catalog it appears as though the spacer is about 1/4". I'm going to fabricate a spacer and can probably figure it out by trial and error. However if someone else has one apart and could measure and share the spacer thickness it would be much appreciated. Thanks in advance!! ...Bob M
Punch below for a few photos of progress so far...
Post A Followup
: Re: Super H steering mechanism - need help!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
