Farmall Tractors Discussion Board
350 International hydraulic problems
Posted by Wayne on February 11, 1999 at 16:09:52:
Hi:
I just found your message board. I recently acquired a 350 International with loader from my Dad's estate. Serial # 12082. A 1957, I believe. It hadn't run in about 1 year, but engine always has worked well.
Once we got the engine going (had to clean carb & tune-up), we could not use the hydraulics. It has Hydra-Touch. A mechanic friend & I took it apart. The hydraulic filter screen was completely plugged. We cleaned that & put in new oil. Loader & 2-Pt goes up & down, but it doesn't always respond right away. Could there be air in the lines somewhere yet? Or is there a problem with the pump?
Also the bucket will sometimes slowly creep down. Is that a seal problem in the cylinders?
The third problem is the power steering. According to the book, the power steering flow control valve is supposed to give priority to the power steering. But the power steering does not work if the valve lever for the loader is open. My dad had problems with that for several years.
Any ideas? Your help would be appreciated. Also, any ideas on the approximate value? It is in decent shape. Typical farm tractor. I live in Minnesota.
Post a Followup
: Re: 350 International hydraulic problems
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
