Farmall Tractors Discussion Board
Oil pressure to cyl head
Posted by Stan(VA). on February 12, 1999 at 10:05:25:
I just put together a Super C motor and don't appear to be getting any oil pressure to the
top of the engine. I've started the motor 2 or 3 times and run for less than 60
seconds each time. (I don't have the front end or radiator back on yet so
just checking for early trouble)
The oil pressure guage goes all the way over, and there's plenty evidence
of oil in the bottom end. I didn't have the oil filter can seated right so
that leaked all over. Each time I shut it off and pull the valve cover, no
oil gets up there.
I pulled the hollow stud that the oil is supposed to come up through to the
rocker arm and ran about a 9-10 inch wire down without finding any blockage. That
gets about 4-5 inches beyond the cylinder head into the block. I poured oil
down in the hole and it slowly drained down into the block. If I am reading
the manual correctly that passage is fed from the center cam bearing.
Is it possible that I'm just not running it long enough, or should it get
oil within a few seconds of pressure showing on the guage? Is it reasonable
to take 1 to 2 minutes to get pressure to the that passage? If it is then I
could put the radiator back on and run it for 20 minutes to warm up then do
a last check for oil to the top end. If it matters, the block is a SC block
from a salvage yard, that was hot tanked and checked OK for cracks. Head was
also cleaned up and milled. The crank and cam came from a B motor.
Everything fit together well.
I'm running out of ideas so any help would be appreciated.
Thanks,
Stan(VA).
Post a Followup
: Re: Oil pressure to cyl head
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
