Farmall Tractors Discussion Board
Re: IH 300 has leaky axle seal
Posted by RickB. on February 13, 1999 at 14:56:36:
In Reply to: IH 300 has leaky axle seal posted by Bartman on February 13, 1999 at 09:15:20:
Kurt & Mark are describing a Farmall 300 (rowcrop). Shawn is describing the International (utility) version. Be careful with the wheel assembly, it can weigh over 1000lb if loaded with calcium, and wheel weights. Check the outer axle bearing by watching the axle shaft as weight is taken off the wheel with a jack. You should see no vertical movement of the shaft in relation to the axle housing.
Post a Followup
: Re: Re: IH 300 has leaky axle seal
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
