Farmall Tractors Discussion Board
Re: Hard/soft water
Posted by DM on February 19, 1999 at 20:38:49:
In Reply to: Hard/soft water posted by Pete B. on January 01, 1999 at 18:44:16:
Have you ever had a problem with a car or other water cooled engine having heating problems. If you have, you have reason to want to use distilled water in your radiator. Tap water, in most cases, has large amounts of calcium and other minerals in it. It causes scaling in radiator cores as well as water jackets of the engine block. Antifreeze solution helps to a point, but when you have an iron block that is partially rusty, don't make the situation worse. The same is true for your batteries. If they need water, it should be pure. Electrolyte comes from the Sulfuric Acid that is added to new batteries. I would not reccomend using softened water for fillups. I do not think you can be sure how well the salt is flushed out after the regeneration cycle.
Post a Followup
: Re: Re: Hard/soft water
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
