Re: Advice about buying a Farmall H
Posted by Bob M on June 12, 2001 at 18:41:48 from (66.66.72.246):
In Reply to: Advice about buying a Farmall H posted by Dan B. on June 12, 2001 at 18:02:44:
First make sure it REALLY is a Super H you're looking at - not just a regular H with "Super" decals applied. Spotting tips: Disc (not band) brakes; C-164 engine (numbers cast in the block near the serial number); last digit of "Y" on date code most major castings. If it's got a loader it should have a live hydraulic pump with reservoir under the gas tank and the battery under the seat. Once you've established is truly a Super H, look/listen for the normal stuff: Knocks or raps from the running engine, blue smoke in the exhaust, water in the crankcase, oil in the cooling system, leaks or drips from motor, cooling system, carb, hyd system, transmission. Run the tractor in every gear listening for gear whine (worn gears/bearings) or repeating clicks/clunks (busted gear teeth/bad bearings). Run it in road gear and check the front wheels for wobble (worn steering parts). Also try to stop it with the brakes while in road gear - brakes should be able to slow the tractor and load the engine, and the clutch should not slip. Look for blowby escaping from the crankcase breather tube (right side of motor below and behind the oil filter) with the motor loaded. Check the oil pressure both with motor cold (should be high) and warmed up/idling (needle stays out of the red). The ammeter should show charge at all speeds above idle. Nice if the temp gage works, but often it won't on an older, working tractor. Finally look at the shape of the tires. Fronts are cheap and easy to replace, but a new set of rears will run $600 or more. I'm sure others can add more, but this will get you started. Good luck! I own a '53 SH - it's a great tractor!!
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
