Re: Re: Re: Re: Re: Re: electrical problem Farmall 460
Posted by Red Dave on June 17, 2001 at 16:42:47 from (64.41.22.234):
In Reply to: Re: Re: Re: Re: Re: electrical problem Farmall 460 posted by The Red on June 17, 2001 at 08:12:06:
Put your voltmeter from the hot side of the points to a good ground (not on the distributer itself). Pull the coil wire to the center of the distributer off so it can't start. Crank the motor, by hand if you can, if not use the starter. Watch the voltmeter. It should alternatly show 12.4 volts and then zero volts (or close to it). If the volts remain steady, the problem is in the points, if the volts go up and down, the points work and we should look somewhere else.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: electrical problem Farmall 460
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
