Anybody heard of using copper water pipe as hydraulic line?
Posted by Will on June 18, 2001 at 17:28:58 from (208.28.190.95):
A drawbar-only Farmall 560 I just bought uses standard copper water pipes to extend two steel hydraulic lines that run from the hydraulic valve complex to just in front of the seat mounting box. The copper lines run rearward to a block that has two standard hydraulic line connectors for attaching implements. The copper lines are connected by standard plumbers compression fittings to the steel lines. Under load (lifting a big disk harrow)one of the steel lines keeps busting away from the compression fitting because the whole line (steel + copper) is able to flex just enough sideways to pull the steel pipe out of the compression ring. The neighbor I bought the tractor from says he was thinking about going to flexible hydraulic lines to extend the steel lines. I don't feel very comfortable running copper pipe on a 1500 psi or so hydraulic system but maybe I'm wrong. Anyone else using copper? If I go to steel pipe are there steel compression fittings? Would flexible line be the answer? Should I try to stablize the line laterally? Thanks.
Post A Followup
: Re: Anybody heard of using copper water pipe as hydraulic line?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
