Stumped on C problem
Posted by FC on June 25, 2001 at 07:13:57 from (208.14.16.15):
Ok guys, I don't know what to check next. Here is sequence of events up till now. Would not start, appeared to be dead coil (had no secondary voltage from coil) Replaced coil, and fired off fine Ran fine about 20-30 minutes, then died as if switch was shut off Restarted, but needed partial choke to run well at all Checked fuel flow to carb, seemed ok Pulled carb (twice) and cleaned, checked well and found no problems. Pulled distributor, advance was gummed and looked to be sticking Cleaned distributor, and replaced springs on advance, lubed weights,etc, filed and set points to .020 Restarted, but still surges at lower throttle, runs better at higher throttle, but not up to par with what it should be or was. Timing changes will allow better idle, but not right. I am now beginning to wonder about the new coil I put on. Anyone seen a coil cause this type problem? Points, condensor, cap, rotor, carb rebuilt about 30 working hours ago, and was running fine. I believe the surge is from engine nearly stalling, and governor opening then tractor fires back up with higher throttle then cycle starts over again.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
