Re: Re: Re: Re: Re: oil pan leak
Posted by Bob M on June 26, 2001 at 10:08:31 from (192.232.119.194):
In Reply to: Re: Re: Re: Re: oil pan leak posted by Todd on June 26, 2001 at 08:59:24:
Todd - So long as the pan flange is flat within 1/8" or so, I've had good luck sealing slightly warped pans with Permatex red silicone gasket maker. Start with the pan flange, mating face on the block and the gasket thoroughly clean and degreased. Run a bead of silicone about 3/16" diameter all the way around the pan flange, keeping it to the inside of the bolt holes. Position the gasket over the flange, line up the bolt holes and lightly press it into the silcone. Now run another 3/16" bead all the way around the upper side of the gasket. Finally carefully position the pan and bolt into place. Wipe off the excess silicone that gets squeezed out, then give it several hours to cure before adding oil and starting the motor. I've found a couple long (6" or so) bolts - same thread size as the pan cap screws - are helpful holding the gasket in place when postioning the pan against the block. Also be careful to not overtighten the pan cap screws - you just want to good bead of silicone squeezed out out all the way around the outside edge of the flange. Seems to me 10 - 15 ft-lbs on the cap screws is enough. Good luck!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
