Need Help! H dieing at high RPM under load
Posted by Weekend Farmer on July 16, 2001 at 04:54:11 from (207.251.209.83):
This spring when I went to start up the old H for the year I recieved a nasty surprise. Not only was my tarp gone but the gas cap was missing & the tank had a water/gas mix.
This weekend I was finally able to do something with it(been growing new skin most of the summer after a motorcycle accident).
Drained the crud from the tank. Cleaned/rebuilt the carb (the float bowl was full of water & rust was starting all over).
It starts & idles nicely. The problem is when you rev it up to mow it may give you up to 20' & then will sputter. If you hit the clutch & throttle down it will stay running. If you only hit the clutch(without throttling down) it will die. It starts right back up, but this game gets old fast.
Any ideas???
Thanks
Weekend
Post A Followup
: Re: Need Help! H dieing at high RPM under load
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
