Farmall Tractors Discussion Board
PTO turns with lever down; and seems to slip
Posted by charles on February 25, 1999 at 17:38:17:
I've got a IH 340 Utility with an independend PTO controlled by a level on the right near the fender.
To engage it, you lift it up and its got a little lock. Two problems: 1. When in the "off" (down) position it really doesn't stop turning any more - which makes putting on the shaft really hard since I have to cut the engine off and the hitch drops to the ground. 2. When I bush hog it cuts OK if the grass (or brush) is short but if I put a load on it (higher grass) it seems to slip and just stop turning - so I have to make several passes cutting just a little each time. Really slows things down.
Suggestions?
Post a Followup
: Re: PTO turns with lever down; and seems to slip
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
